High tech Nikie engine
Engine troubles? Try here.
Post by Jim LaGuardia »
Just finished this project.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Profpinz
Post by Profpinz »
So what are the engine specs now Jim?
http://www.ozpinz.com
95mm bore, 8.6:1 compression, High torque 4000+rpm cam. Graphite coated Pistons.
Aluminum Niki cyliners
It sounds good on the test stand :D
Profpinz
Post by Profpinz »
Very nice! :D
Fantastic!.... Maybe you'll find time to upload an audio file/video at some stage.
Willie
Niki Engine
Post by Willie »
Someday maybe mine will quit so I can have the excuse to have one of those!
Awsome!!
MASSIVE PINZ
Post by MASSIVE PINZ »
I've been using these cylinders since 1999, ... They are amazing!
Curious as to what skirt clearance and ring gaps you used? did you set ring gaps both at cold and hot temps?? did you use a low tension ring? I'd imagine since those are 95s that you used a Porsche ring pack for Nikisil.
Building an engine with these cylinders is quite a bit different than anything else most people have experienced.. I have ran as little as .00075 skirt clearance with these cylinders and rings gaps as tight as .005 on a 4.137" bore measured at 68*F.... AMAZING!
Oil consumption will now be non-existent!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
Here's a short video clip of the engine running.
