VDO speedo setting
VDO speedo setting
I have a new VDO speedometer that I am having trouble calibrating. I tried the autocalibrate method and it didn't work, so now I am trying the manual method. Does anyone know the value that you need to enter to calibrate it manually? The paperwork from SAV says 12520, but I tried that and it didn't work. I'm running BFG M/T tires.
Sean
Sean
- David Dunn
- David Dunn
I don't have the instructions in front of me,but be sure to have it in the right programing mode. It will also give an error if it is out of parameter.
I have done a 710,712, 716 and a 700 with the VDO on a mile...and amazingly, all of them and 3 other of my trucks have run a 26 mile fire trail and had the same results.
The sender is located under the driver side. Just follow the black cable from the back of the speedometer, it should go through a hole on the driver's side, down to where the sender is screwed on. I won't promess but I will go out when the rain ends and take a picture for you. Not rocket science. Just follow the cable.
CHACAOCOP
1973 712M
1973 712M
