Good Morning All.....
I've tried searching the archives but havent seen a 100% similar problem or description of starting problems, so I'm hoping that someone more familiar with this may be able to point me in the right direction.
My initial guess is a dead spot but having never run into a starter problem I am not sure if thats an accurate description.
Twin Optima red tops, test ok at 24.90 V
Ground strap is good.
Turn the key to the on possition and hit the starter... Every once in a while there is a clunk (sounds like the starter gear moving out to grab the flywheel and then, Nothing). no whirling, no grinding, its almost like a complete loss of electrical power. Release try again.... sometimes it will happen again, most times it will kick it over.
Almost NEVER happens when cold.... Not sure if its related to the hot/restart problem though.... I've got that issue as well lately. After the truck has been run, its NOT wanting to kick back over but that seems to be a more common issue.
Any ideas on what to try, test?
Dave
Symptom of a bad starter?
1973 710K
The Ark
The Ark
Hold on there green horn and get out the service manual
Starter replacement/repair is fairly simple and does NOT require gas tank removal
Remove the dipstick tube to access starter removal
Brushes are easily replaced, but it is most likely a solonoid issue or bad (loose)connection.
If you are uneasy about repairing it, then buy a rebuilt unit from E.I. or SAV.
As Jim said removal of the starter is simple.
Recently I had to pull the starter a few times (long story, but it harks back to my full 12 volt conversion) and it was out and back in, quick-smart!
1997, 718 6X6 Pinzgauer
Pinzgauer Pete
