I'm looking for a source for all 3 windscreen rubbers. Having to replace all the glass so want to fit new rubber seals. Anyone done this?
Steve
Windscreen rubbers
Re: Windscreen rubbers
For what type of vehicle, Pinz, Hafi, Volvo?
Pinz has 1 rubber for the "Swiss" version (one pain of glass), 2 for "Austrian" (two pains of glass)
dono what uses 3 rubbers?
Depending upon the truck there are several on the forum who can give you some tips -- which
will cost you at least adding your location to your profile
Suitably chastised.
It's for my Volvo c304.
Check out my blog for my restoration progress
http://Www.pearman.cc/blog
That 304 sure looks like it is coming along !
Post a shot when your done.
cheers
cheers
Did you happen to find a source yet? It rained quite a lot here overnight and I noticed a bit of moisture in the footwell of my Volvo. Thinking it's time to look at replacing these and address windshield frame issues.
I checked these two sites but haven't contacted them to see if they have any but are not listed.
http://fmv4x4.com/web/
http://www.tatanka.nu/
I tried to find a source for pattern rubbers but nothing.
This is what I came up with. Not done it yet though, read it from the bottom up
Hi Steve
Yes that is correct.
Phil
Sent: Tuesday, November 17, 2015 1:37 PM
To: Phil Howard - Seals + Direct Ltd
Subject: Re: Website Contact Request
Thanks Phil
Do i take it you'd mitre the seals to the right shape then fit to window opening. then fit glass and use the s136 to then fill in the corners? rather than trying to create a single jointed seal before fitting glass?
Steve
On 17 Nov 2015, at 13:08, Phil Howard - Seals + Direct Ltd <sales@sealsplusdirect.co.uk> wrote:
Hi Stephen
You can cut and mitre this section and bond together using S136 to make a frame shape.
Best regards
Phil Howard
Seals + Direct Ltd
Unit 6 Milton Business Centre
Wick Drive
New Milton
Hants
BH25 6RH
Tel: 01425 617722
Fax: 01425 610967
E-mail: sales@sealsplusdirect.co.uk
Web: http://www.sealsplusdirect.co.uk or http://www.sealsdirect.co.uk
Hi, I have a set of 3 window glass seals that I need to replace. It's from a historic vehicle so no chance of finding new ones. I was looking at Window Rubbers (Claytonrite) but the windows have 90 degree corners so I won't be able to bend the seal. Is it viable to cut and glue 4 sections of seal together to form 1 new seal? Steve
Hi Steve
Phil
Thanks Phil
Steve
Hi Stephen
Best regards
Phil Howard
Seals + Direct Ltd
Wick Drive
New Milton
Hants
BH25 6RH
Tel: 01425 617722
Fax: 01425 610967
