Transfer case shifting is speed dependent. It can be done stationary or moving, but there are a few rules.
Shifting the transfer case from
Lo to Hi can be done without concern for over-revving the drive train. At worst, you will be in too high of a gear in the transmission and have to downshift.
But when shifting the transfer case from
Hi to Lo, you MUST be sure you will not over-rev things. Your vehicle speed must be slow enough that when you shift from Hi into Lo range, you are at an appropriate speed for the gear you will be in. For instance, here is no appropriate gear in Lo range for 50 mph (you cannot reach 50mph in Lo range), so if you shift into Lo at 50mph you will have issues.
63rover wrote:
The truck has to be moving for 4 wheel drive to engage.
PS Ever notice that the lockers tend to have minds of their own too? Pull or release a lever and the the light will come on or turn off to indicate success only after everything lines up just right for the action to take place.
PPS One last thing, Never force a stuck lever on or off. I only had this happen once. Some gentle back and forth released the problem. If it refused to let go I would have had to jack up one side of the offending axle to release the binding pressures.
The truck does not necessarily HAVE to be moving to engage the lockers, depending on how things line up internally. But you do want to be a bit gentle on them.
Pulling a locker lever down puts pressure on the locking mechanism. It acts by sliding a collar around two splined shafts, thus locking them together. If the splines align with the collar, it will engage directly - even if the truck is parked. But if the splines do not align with the collar at that point (very common), a spring is depressed which maintains pressure on the collar. As soon as the splines do line up, the spring engages the locker. The indicator light will only illuminate AFTER this locking has happened. This is why the indicator light may not illuminate immediately when the locker lever is pushed down.
Same thing happens when you release the locker lever. The locking mechanism will unlock immediately unless the gears are loaded. If the gears are loaded under pressure (maybe due to turning, etc.), then the locking mechanism may stay engaged until the pressure is relieved (like by clutch in or going straight for a while). The indicator light will only go out after the locking mechanism has actually disengaged.
If you lift the locking lever but the indicator light has not yet gone out (locking mechanism is still engaged, likely due to loaded gears) and you then try to push the lever down, you will be trying to force fluid into an already filled slave-cylinder and the lever will feel like a rock. Further force will break the lever mechanism. The locker must disengage and the indicator light must be out before you can again push the locker lever down safely.
