No Spark
No Spark
Any help on this would be greatly apreciated, My 712 has no spark. I have power at the coil and even to the cap. I have replaced the points twice now with no avail. When I pull the plugs they are damp with gas so I am assuming that it is getting fuel. It just cranks and cranks with not even a sputter. The reason I know there isn't a spark is I have pulled the coil wire and a spark plug wire with plug and touched it to metel with nothing. Is there something inline that I coudl be missing?
Wimps Need Not Apply
The condenser is the small can with the green wire that is pressd into the bottom of the dist.
Try this first, remove the distributor signal wire from the coil(-) and clean the contact surfaces and re-test for spark
I have found this work on at least 2 no spark conditions.
As for points, why are you not using Pertronix
You will get a smoother idle and less stumble with a Pertronix unit than with points.
I didn't communicate this very well - I do have a full Civi ignition kit installed and I have changed out the coil and ignitor now with new ones with no change....So everything is new. Still getting power but no spark...
Is the condenser the cylinder that is under the coil to the left and connects to the coil?
- David Dunn
Im Just trying to keep you on your toes Jim....I know you don't get enough of that. Didn't I mention that?Jim LaGuardia wrote:The plot thickens!
If you put the Pos wire for the winch to the starter terminal, I would be looking for a wire with a ring that is not attached to the starter stud where it should be :idea:
