Axle split boots ???
Locked
Denis
Post by Denis »
Before the site was hacked, there was a post that said the split boots on the left side had to be facing rearward and the right ones facing foward...
Am i right or it doesn't matter :?:
Thanks :D
Denis
rollingpinz
Post by rollingpinz »
Hello
I can't see any reason why it would matter unless some one was convinced that the way that the two sides "keyed" into eachother mattered. Maybe they were trying to describe having the nuts on the bottom so that if they fell off, the screw would still be in place as a pin. But, then again, maybe they were trying to describe a method such that the joint faced to the rear for protection.
Eric P
pinzdriver
split boots
Post by pinzdriver »
Denis you are right the left side to the rear and the right side to the front this way they conform to the off set axle housing.
:D
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
Denis
Post by Denis »
Thanks Pinzdriver. 8)
Denis
Ugo
Post by Ugo »
About split boots, there are some that are being sold "without hardware" for cheap.
Can screws and collars from a failed stock yellow boot be also used with a split boot? Or are they not compatible?
Ugo
1977 710K
1990 716K
Torino, Italy
Post by Jim LaGuardia »
The yellow boots(1 piece) do not use screws and are thinner making clamp re-use difficult.
I have had some clamps fit, but for the most part is is best to buy boots with all hardware, unless you are replacing an existing split boot :wink:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Locked
