Hello
Man nobody' posts down here!!
Looking for a 639991-9 Diaphram for the vacuum servo that activates the transfer case from AWD to RWD.
Also may need two CV joints for the front axle
Manny
Parts Needed
lindenengineering
Thats Great
I am going to need the whole assembly, looked at it today and the housing is also cracked
Also I have a bad bearing on the transfer case on the front shaft output.
If wife gives me time I will start dissasembly today to start exploring.
keep you informed. I would imagine you also have a complete transfer case should I end up needing one.
This is for a 6x6 Tgb13 that I just had shipped over from Sweden. Picked it up at port of Jacksonville, FL on Friday. Drove it back to Ft Lauderdale yesterday.
I thought I had a bad CV joint on front axle because I heard a clanking noise while turning, remember I had 6x6 permanantely engaged. But after spinning wheels with truck on jack stands I think it is comming from the transfer case.
Manny
Manny
lindenengineering
