Refinishing the rub rails.
Twin Pinzies
I was just wondering if (and how) some of you have replaced or refinished your wooden rub rails. I've seen metal, rubber, and, synthetic wood used in place of the factory wood. Any stories?
rub rails
Lots and lots of sandpaper and elbow grease.
Seriously. Use a paint stripper to get most of the paint off, and then use an 80-grit sandpaper to remove the paint and grayed surface.
Use finer papers until you get to around 320 to 400, then stain, or coat with a clear polyurethane.
Once dried, lightly go over this with 400-grit paper and recoat with the polyurethane. Repeat as necessary.
Steve
1973 712M
Steve
1973 712M
Pinz Enthusiast
I've redone mine with Herculiner bed liner, couple of good coats and after a year of bashing into the rocks and trees, a few small spots need touch ups, though that pales in comparasion to the fact that mine are rotting away from behind, one has split so I now have a front and rear section, new ones will be getting the bed liner treatment though, sooner rather than later I hope.
Eric
Anaheim Hills, Ca
1973 712M
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
Anaheim Hills, Ca
1973 712M
1996 LR Disco I
Twin Pinzies
What's with the phenomenon of Pinz owners refusing to do anything to the exteriors of their rigs? I know, I know, it's not a fashion show but sheeesh... I've seen folks fixate over little details like motorized window washers, remote controlled shock adjusters, engine swaps, fuel injection, etc, ... After putting thousands of dollars into their Pinz, it still is a rusty, blotchy, poorly painted, eyesore with rotting wood rails! What gives?
Hey!! I resemble that remark, 'cept I have part desert tan.part rust colored u-channel for rub rails.Twin Pinzies wrote:<snip>After putting thousands of dollars into their Pinz, it still is a rusty, blotchy, poorly painted, eyesore with rotting wood rails! What gives?
Mike Newton 1973 712M (sold)
Shiny paint is too girlieTwin Pinzies wrote:What's with the phenomenon of Pinz owners refusing to do anything to the exteriors of their rigs? I know, I know, it's not a fashion show but sheeesh... I've seen folks fixate over little details like motorized window washers, remote controlled shock adjusters, engine swaps, fuel injection, etc, ... After putting thousands of dollars into their Pinz, it still is a rusty, blotchy, poorly painted, eyesore with rotting wood rails! What gives?
Months and numerous dirt roads and tracks add to buildup layers...thus integrated into the O.D.
My wife wants me to do a "Rasta Digital" camo paint job to defy the often negative association some folks give any "military" type O.D. vehicle.
I just can't bring myself to do it. I just tell folks, "hey, this truck was in the Swiss military, they have never been in a war!"
My rails have so many layers of paint on them you can hardly tell they are wood! I think that is what holds them on too! (Last owner did create a mess by replacing lost 6mm screws with sheet metal screws that of course reduced the internal threads to nothing). Lazy bugger...
1975 710M
