Weird LED symptom
Locked
todds112
Weird LED symptom
Post by todds112 »
I got one side of my LED upgrade done. Keeping it simple using a single Stop, Turn, Brake light. I have read that I might need an electronic flasher unit, others have not needed it. Well I tested it and found that I was not getting the click-click inside and the dash indicator was not flashing. When I stepped out, the lights were flashing normally (front and rear). Guess I'll need the flasher after all.
Weird. :roll:
1973 712M
todds112
Post by todds112 »
Got the Signal-Stat ecltronic flasher from NAPA. Works great. Had to bend the rear braces in just a bit to clear the lights, but got everything installed. Do need to get one new reflector that I broke accidentally. :roll:
1973 712M
milesdzyn
Post by milesdzyn »
You might find one that matches here twards the bottom of page:
http://www.saturnsurplus.com/lights/lights.htm
Lots of 24v lights, Reflectors and Marker lights. I think they also have the original replacement headlight bulb for the Pinz "Hagglunds Replacement Bulb" didn't say if it was 24v or not though.
Miles
'73 Pinzgauer 712M
todds112
Post by todds112 »
Thanks Miles, I found some on Ebay identical to that. Bought 2 so they will be the same.
1973 712M
Locked
