Well I look at my small MityVac fluid changer and then I look at all the fluids in the brake system, the transfer case hydraulics and my hand starts to ache thinking about all the hand pumping. What brand of brake fluid changing equipment do you guys use? I want to upgrade to a larger set up but there seem to be a lot of choices. I don't want to spend over $150 if possible.
Thanks!
Bruce
Fluid changing hardware
1975 710M
"equipment"
I use my wife and a bottle of brake fluid. Works great. Probably costs more than 150.
bleeding brakes
I got a power bleeder from EI when I had my Mog and it works great on the pinz as well. Best investment $ going. It takes one person to do the whole thing, as I am usually working on the stuff when no one else is around, it is very good for me.
Morris
Morris
I narrowed it down to the black Motive bleeder offered by EI. I have several other vehicles (VW, Isuzu) that it should work on too. It will be nice to have a more "robust" unit instead of the small hand held unit from Mity Vac. Said unit works fine it is just a lot of hand pumping the whole time you are bleeding. Thanks guys for your feedback.
Bruce
Bruce
1975 710M
