Battery chargers
Locked
M Wehrman
Battery chargers
Post by M Wehrman »
I am thru with splitting the batteries to charge during non use. :x 24v chargers seem over-priced :shock: ,other options?
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Thomas-E
Battery Charger 24 volt
Post by Thomas-E »
I found and purchased one from Harbor Freight
Model # 91325-0VGA
It is a dual 12/24 switchable unit, I'm happy with it and the current price is $49.99.
It is occasionally on sale in their catalog, about $30.00 :D
Thomas E.
712m
Sonora, CA
M Wehrman
Post by M Wehrman »
Thanks,spent a lot of time there...didn't think to check. :oops:
Mark
68 Haffy
ms1223
Post by ms1223 »
My batteries would run down in a couple of weeks when sitting after I installed the battery equalizer. This solved the problem. A Soneil 24v 1.5 amp (electronic maintainer) battery charger. I leave it attached to the battery handles in the battery compartment. Cord tucks in between the two batteries.
Swifty in Illinois
http://www.batterystuff.com/battery-cha ... t/0-4amps/
Swifty 72 710M
Foz
Post by Foz »
I use a 20/12 amp battery balancer - which is wried to a 12v to a marine type fuse panel like this:
http://www.boatersworld.com/product/196 ... 3Bcipanels
I added switches to lift the 24v and 12v connections to the balancer so I can turn off the balancer and the entire 12v panel - which brings the quiescent drain on the battery bank down to near zero when the truck is parked.
Foz
Locked
