electronic flasher
Locked
chapel2
electronic flasher
Post by chapel2 »
I remember the SDP pinzgauer site having a thing on converting the flasher to an electronic one, can anyone tell me how to do that? The current flasher dosent like my led turnsignals
jeff
I believe it's NAPA part # EG23. It is electronic and is what I am using but I don't have LED lights. You only use 3 wires for it and I haven't been able to find my notes on which 3 but I will keep looking. You might do a search on this forum for "flasher" as I know this was covered before.
Thomas-E
electronic flasher
Post by Thomas-E »
I found a listing of electronic flashers that should work.
See SDP Site for use;
http://www.sdp-pinzgauer.org/html/elect ... asher.html
Buss BE234
Bussman BE234
Grote 44860
Napa EG23
Truck-Lite #92702/04?
Signal-Stat 263-4?
I'm using the Signal-Stat 263-4, it works fine. I mounted it with an "adel" cable clamp.
The New flasher will have three terminals, marked with P, L and X.
Remove the terminals from the old flasher one at a time and connect them to the New flasher
Old terminal 49 or 49+ goes to New X
Old terminal C goes to New P
Old terminal 49A goes to L
Unit works great and solved some slow flashing for me :D
Thomas E.
712M
Sonora, CA
MarkPinz
Post by MarkPinz »
The only time I have used my flasher has been ascending steep hills to warn the speedy ones behind me :x Did notice things started to get a bit warm near the switch :shock: will replacing the flasher cure these concerns?
Just get in and go....
chapel2
Post by chapel2 »
MarkPinz wrote:The only time I have used my flasher has been ascending steep hills to warn the speedy ones behind me :x Did notice things started to get a bit warm near the switch :shock: will replacing the flasher cure these concerns?
Even without LED bulbs in, the flasher gets burning hot after about a minute of having the turnsignal on.
It will work... sometimes if i hit it pretty hard
Locked
