napa auto reference numbers
I spoke w my local napa today for a voltage regu;ator and a flasher they dont show a cross reference for the bussman flasher or the voltage regulator and also whats good for battery replacement
It is only air and fuel ...For every 1 lb boost will gain you 10 % displacement
V.R.
You need to check the other posts, this was just discussed two topics down from this one.
Try...
Superior Distribution Center Inc.
P.O. Box 2909
1142 South First Street
Turlock, CA 95381
Toll free: 1-800-457-1728
Fax: 209-667-8208
Order- Renard #35-9128 (24V)
(Exact Replacement for Wilson 62-15-6647)
This is where I found one.
Tom E.
712M
Sonora, CA
Try...
P.O. Box 2909
Turlock, CA 95381
Fax: 209-667-8208
Tom E.
712M
Sonora, CA
Re: V.R.
in respect for others i didnt want to steel the post from someone else but i did check all those part numbers with napa and they do not list them also superior doesnt stock that number either ...but i did say that earlier
Thomas-E wrote:You need to check the other posts, this was just discussed two topics down from this one.![]()
Try...
P.O. Box 2909
Turlock, CA 95381
Fax: 209-667-8208
Tom E.
712M
Sonora, CA
turbojim- where are you located? if you are needing this up and running soon i might be able to help.
i must have gotten the last 2 from EI..
....so i have a spare.
i could send it to you but shipping will be double since i paid it to get it to Alaska.
Shipping to most places in "America" takes about 3-4 days priority mail.
Voltage Regulator Source
I don't know if they are in stock, but a search found another potential supplier....You might try them, www.rcpcanada.com
RCP PART NUMBER: VRB199-4
DESCRIPTION: REGULATOR, BOSCH 24V
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
FEATURES/NOTES: 'B' Circuit
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
64800005 - MAGNETI MARELLI
6480005 - MAGNETI MARELLI
505-057 - MOTOROLA
9RH8091 - MOTOROLA
0192033003 - ROBERT BOSCH
>0192033005 - ROBERT BOSCH<
11548806 - MERCEDES-BENZ
21540206 - MERCEDES-BENZ
350477102 - MERCEDES-BENZ
13335 - Old RCP Number
Thomas E.
712M
Sonora, CA
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
505-057 - MOTOROLA
9RH8091 - MOTOROLA
Thomas E.
712M
Sonora, CA
Thanks nimrod I got hold of willie and hes gonna send me a used one for now he said should be febuary for new onesAK NIMROD wrote:turbojim- where are you located? if you are needing this up and running soon i might be able to help.
i must have gotten the last 2 from EI..![]()
Re: Voltage Regulator Source
Thanks Thomas are all these part numbers for a direct replacement regulatorThomas-E wrote:I don't know if they are in stock, but a search found another potential supplier....You might try them, www.rcpcanada.com
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
505-057 - MOTOROLA
9RH8091 - MOTOROLA
Thomas E.
712M
Sonora, CA
