Miles Pinz Restoration Progress (pic heavy-milestone thread)
Thanks guys, just got the hard top from a 710K today. (Thanks to Dennis @ Linden Engineering) I was going to run a hard top over the rear with the front cab remaining a soft top. But who knows, it could change to a SUT layout as well. Still trying to figure it out.
Erik712m....Just barely, I rolled the bed liner a little thinner at the cover just because of that. I also used a soft 1/4" neoprene gasket to seal the cover on it's edges.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Got the hard top test mounted and some of the cutting roughed out. All the mount holes were drilled into the side rails and I'm happy with the fit so far. It needs some body work done and final cutting at the front roll bar. I will weld the front roll bar into the top and add some panels to the side openings creating a one piece top structure.
As for the top port hatch It will still be usable without cutting the front roll bar, thou I will lose about 3" of access, good thing I've lost some weight.
More pictures @ PinzDepot Body Work Album page
Also replaced all the 6mm rub rail nutserts with 10mm nutserts for extra strength, well worth the effort.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Miles,
Your Pinz is more colorful than a George Carlin monologue.
Funny thing - I was at Dennis's shop while the top was being crated. I scavenged about $1k in parts from the same carcass.
In the interest of political correctness, "Linden" is the name of the shop - a blend of "Dennis" and "Linda" his wife's name. Their last name is Williams.
-Evan
-Evan
Carlos...For now I will just weld in some sheet metal into the window sections, I will only have visual access through the rear door upper section and a portal between the cab and rear. Things may be added at a later date.
Evan... You have no idea how distracting it is not having a solid color, but untill I get all the metal work done my hands are tied. I swear I do have a plan going for the colors, sort-of.
For now I will work on the interior cab parts, since our Mig Welder is on the fritz.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Per request here are some more pics of my shocks and springs.
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Miles,
You must have one big honkin' pile of sand from all of the sandblasting.
Yesterday I drilled, sandblasted, primed and painted one wheel as an intro to my Staun beadlock photo-essay. I used gloss black, and I think it looks the best.
My color scheme will be everything below the rub rail black, and everything above desert tan. My target touring area is the deep desert.
-Evan
-Evan
For the body - Paint stripper and a wide scrapper, followed by a orbital sander with heavy grit 60 sandpaper. I was fortunate in that my body had very little rust, just a few small spots of surface rust.
For the frame members - Angle grinder with paint stripper discs.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Due to the sale of the company I worked for, my priorities have changed, to getting the pinz up and running. The body work will have to be done later as time allows. Here is some pics of the progress to date.
Painting will continue for the lower body and the electrical finished within the week.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Just a quick update as to the body work progress. Mostly done exept for the sheet metal for the hard top.
I've run into a dead cylinder (#2) that's got me a little puzzled. I'm waiting to get my carb bases fixed before I get into it any further.
I'm hitting the back stretch
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
