How fast is too fast?
dokatd
Post by dokatd »
Oohhh witty. Make sure it applies before you use that one again.
pissing contest would be if I went into my driving history.
20yrs total relavent driving.
15+ yrs automotive fabrication
10+ yrs unimog ownership multiple types and models
9 yrs Defender 90 ownership
Both series I and II discos
Owned and driven multiple mercedes from trucks to cars
two late model ford trucks
one GMC racing pickup
late model 1 ton chevy duramax
late model chevy dually
Audi
Multiple BMWs
A fully restored triumph motorcycle
98 honda shadow
97 yamaha royal star
Early ford bronco
mid 90s full size chevy blazer
A toyota or two
Won multiple extreme offroad comps
Hosted several offroad events
Driving instructor for LR dallas wheels events
oh yeah and im an FAA private pilot
should I continue
Now thats a pissing contest
Considering this is all on my Iphone im doing pretty good on the spelling
Erik712m
Post by Erik712m »
EvanH wrote:[quote="Erik712mYou've just aged your self:))
Sorry, Erik, but until you offer me irrefutable and properly spelled proof, I will not believe that I have aged myself.
-Evan[/quote]
Well I'm only two years older than the time frame you have been driving so I'd say you're pretty old:)
Just trying to lighten the mood a little.
dokatd
Post by dokatd »
Lighten the mood, Im having fun. Im used to Pirate 4x4,. This is a cool headed group if I have ever seen one. No offense is intended. Just a good heated conversation. I wouldnt be here if it wasent fun. And I doubt you would post back if it wasent a little fun for you to.
Erik712m
Post by Erik712m »
Nothing but fun.
David Dunn
Post by David Dunn »
Andy wrote:Hey Dunn, don't ya just love it when the young guys get to seeing who can pee farther? :shock:
Andy
Hi Andy,
Reminds me of the guy that posted his resume at the bottom of his posts, a few years back.
I thought for sure he had reinvented the wheel
dokatd
Post by dokatd »
I personnaly like that you now have zero pertinent information to relay in this thread so you have resorted to HS tactics to feel good about yourself.
Consider this my last post in this thread untill you provide substantial information. It has been fun though.
Post by Jim LaGuardia »
Dokatd, I can tell you from experience(and years of driving Pinzgauers) that you have little wisdom...........just wiz................. :o
You must be blind, the top speed question was answered with facts for both 4x and 6x :roll:
There is a reason disk brakes were fitted to the later TD versions........Poor braking under speed and the fact that with offset axles and independant suspension the vehicle will veer to one side or dip in extreem braking.
As for wear, it is fact, not fiction that higher speeds accellerate wear.
I should know as I repair a fair amount of Pinzgauers and see this evidence first hand.
Would you like some worn out bearings or broken housings, burnt up transmissions?
One side note, your 34" tires are a poor choice. If they rub the body while articulating it tends to rip the portal axle from the axle tube$$$$$$$$ We see this a couple times a year, average reair cost around $2600 :shock:
As far as top speed, go as fast as you want, just make sure to bring a change of shorts when you can't stop in time and possibly end up on your side :shock:
I drive in Pinz time (3x more space than normal between me and the car ahead )
As far as stability, just look at the warnings in the operators manual :roll:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Erik712m
Post by Erik712m »
Jim, do you have 34" and 35" confused? Aren't you running 34" big horns?
33", Maxis Bighorns. 34" is in the "too close" range for me, and I have seen damage first hand with that size tire contacting on a 6x6.
David Dunn
DokaTD
Sorry, I posted in reply to Andy's, and didn't know you had submitted a resume on the next page until afterward
pinzwheeling
Post by pinzwheeling »
Wow, when did this board turn into one of these stupid pissing contest boards that most other automotive boards have become?
Guys, this isn't the Civic board, or the WRX board. Can we put our measuring sticks back in our pants?
Facts:
1. Pinzgauers do not handle well at high speed, either in handling tight turns or in braking. They have a high center of gravity, drum brakes, skinny tires and accelerate like a ... Pinzgauer.
2. No matter what your transfer case is, what kind of tires you run, or how much you upgrade your brakes, a Pinzgauer is not a stable platform at high speed. It was never designed to cruise at 70-80MPH, and the risk you take traveling at that speed isn't just to yourself, it's to every minivan driving soccer mom, and every 16 year old newbie driver that makes stupid mistakes right in front of you.
3. Vehicle type doesn't matter. All things being equal, a vehicle traveling at a higher RPM / higher speed will wear out parts faster than the slower traveling vehicle. It doesn't take a rocket scientist to figure this out.
The real question here was the recommended safe speed for both the vehicle and the persons around the vehicle, not the potential top speed of a pinzgauer. In California, you cannot drive a 712 faster than 55 MPH due to it having 6 wheels (I was told this by a CHP officer, so take it for what it's worth) so the point is moot for a 712 out here.
I would cruise my 710 at up to 70MPH up until I almost killed myself slamming on the brakes to avoid a ladder that fell off a truck in front of me. Almost completing a 180 when traveling in a straight line has changed my ways.
Now, I don't drive any Pinz faster than 55. BTW, I have driven over 300 different vehicles in the past 2 years, and approximately 30 Pinzgauers over the past 5 years... Does my opinion count?
Just my $.02
Michael
email: rosenblumm@gmail.com
Awww. Can't I have any fun anymore :cry: I just found the whole thread rather amusing as a quick archive search would have given the same answers
dokatd
Post by dokatd »
We can have fun still Jim.
The problem with the question is, its a bit of an opinionated question. Some people might say that a pinz isent safe over 45MPH and some might argue its not safe to drive on road period (washington residents). I argue its safe up to and around 70MPH. I also argue that you guys are whipping your dicks out over 10-15MPH If I had come on and said yeah, drive 80+, you guys would have more amunition. As for wear, if you read my last posts in detail, you would see that I agree with wear issues, but not to the catastrophic degree you seem to think it is.
andy
Post by andy »
Hey dokatd, I was just funning a little, I darn sure didn't wanna stir up a hornet's nest.
Ya'll drive at whatever speed you can afford and have fun.
Andy
A bar F
The buck STARTS here
www.deerleaseservices.com
Erik712m
Post by Erik712m »
I tend to agree about the damage I bet the majority of the damage was from unchecked fluid levels.
But I still think it is just stupid to drive that fast in a pinz. What's the hurry slow down and enjoy the ride. It's quit fun watching who and what pass. :lol: :lol:
Beer thirty wuoo. Drunk typing to follow. :lol:
