This tool can customize to do? His size?
http://s881.photobucket.com/albums/ac14 ... t=aaaa.jpg
Re: This tool can customize to do? His size?
[quote="sjuns"]This tool can customize to do? His size?
I need this tool,his size?sjuns wrote:This tool can customize to do? His size?
Twin Pinzies
i know!.... it's amazing.... it seems they figured out what he was trying to say! i know in switzerland everything is assigned a male or female status.... even a chisel
1973 710m
Sjuns, I believe most Pinzgauer mechanics do not use the "factory" tool. We use amost any kind of tool to wedge the outer axle gap apart to allow for removal. Most use a cold chisel, the kind for cutting metal, concrete, or similar materials. Just find a chisel that is about the correct size. You can grind the chisel end to best fit the slot in the axle. It is not mandatory to use the factory tool.
Best of luck,
Jim Mettler
Best of luck,
Jim Mettler
