Coolant pump needed
Coolant pump needed
Anyone have a cross over application for the water pump or a supply source?
wrangler_tj
lindenengineering
Guys
The pulley and the offset are different on a c303 and 164 car pump.
Obviously it is easy to remove the pulley flanges however do remember that some flanges are made in cast iron and can shatter upon pressing off and on the shaft.
Care needs to be taken when pressing on a flange to a new pump so that the gland and shaft are not displaced by the pressing activity. Furthermore the shaft must be supported during the pressing activity by virtue of the fact that it sits inside the case . Hence do NOT the pump casing.
Dennis
Dennis
OOOps no customer bashing now
