left works great - swapped bulbs from left to right...no change.
right signal on and right front doesn't light up but the back tail light comes on but not flashing.
just thought i would put it out there before I start going crazy tracing things out.
Thanks jer bear
right signal lights not working
so we have 4 ways - hazards - backup lights and left signal.
when I try the right signal the light on the right comes on but it's dim..we opened up the waterproof box and swapped wires and the wire to the tail light are fine...they work of the left signal wire.
I am thinking it's grounded out somewhere...we ran a wire straight from the power on the flasher to the tail light and it cam on FULL bright.
Does anyone know what colour the wire is from the flasher to the rear junction box.
It's BLUE on the flasher (green hot) and the left signal is yellow with a black stripe
thanks
jer bear
thanks
jer bear
There is no wire that goes directly from the flasher relay to the rear junction box. Both the black/yellow and green wires from the flasher go into the hazard switch which in turn feeds the turn signal switch. Right rear turn signal has a black/green stripe wire going to the turn signal switch. On the left rear it is a black/white stripe wire. Further confusing the issue is that when those wires reach the turn signal switch connector they change color.
Don't know if you have a schematic but if you don't you can download one from me here: http://www.milkrunfarm.com/sitebuilderc ... iclgnd.pdf
It's a large file and may take a while.
Hope this helps,
Hope this helps,
So i fixed her up...did it the old way put power cut and splice technique.
So I found I couldn't get 24 volts at the terminals of the signal switch on the right hand side (black and green) with the wire connected to it.
So I cut it....sliced a wire from the switch to the right signal light where it goes through the firewall below the glove box (I had cut that wire too).
Bingo lights....now there was two black and green wires that connect from the switch to a double spade connector....so I eliminated the bad on and put a new spade connector on my freshly run wire and tied her all in and she is working like a charm now.
thanks for everyones help.
Jer Bear
Now I am just waiting for my two carb kits - she is back firing bad right now and NO power..parts are ordered
Jer Bear
