Muffler removal - can I just cut the bolts?
spandit
Post by spandit »
The nuts holding the muffler/silencer onto the heat exchanger don't look like they're going to be willing to come undone any time soon - looking at diagram 1.55, it seems part 72 is just a short piece of M8 studding, albeit with a non-threaded portion in the middle. Can I just cut the nuts off and replace with normal studding or bolts (if I can get them in)?
I'm pretty sure the answer will be "yes" but thought I'd check!
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Post by Jim LaGuardia »
You can cut the 6 flange bolts, they are 8x 1.25 bolts with nuts.
Do Not cut the mounting studs for the front mount assembly :roll:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
spandit
Post by spandit »
Not sure how I'm going to cut them - not a lot of clearance up there! Might have to see if I can wangle a spanner in there.
On closer inspection, the tailpipe was completely rotten so I've cut it off. The stub (about 4") that is left is in OK condition and there are a couple of small holes in the muffler/silencer which I'll try patching...
...now where's the JB Weld? :)
Robin
Pinzgauer 710K
MegaJolt ignition
Use your noodle, get the blue wrench out (torch) and burn em out. :shock:
It is usually quicker and less messy though to use two long wrenches and break them off :wink:
spandit
Post by spandit »
Jim, you don't know me very well. If I had access to oxy-acetylene cutting equipment I would have died from the resulting explosion long ago :D
Will try snapping them off - good job I've just bought some new spanners!
Robin
Pinzgauer 710K
MegaJolt ignition
Squiggas
Post by Squiggas »
I had the same problem. Got them off with a nut splitter.
Bryn Pinzgauer
Post by Bryn Pinzgauer »
Nut splitter worked a treat here too, although I took both the silencer and heat exchanger off first to get better access.
Pinzgauer 710M
