Where can i purchase a wrench for brake bleeding?
- audiocontr
The manual shows a nifty pass through wrench for brake bleeding. Any idea if these are a common tool? Where can i pick one up? While i have your attention, what size do i need?
SAV sells that here: http://www.pinzgauer.com/showdetails.ph ... 9053258012
Possibly Scott at EI carries one also though I couldn't find it on his website.
I've got one and it really is a nice tool.
blackstack
SAV one seems awfully pricey when a normal wrench/spanner would do - can't remember how deeply inset the bleed nipples are, think I undid mine slightly with the spanner, then put the tube on, and just used finger tightness whilst bleeding, then finally tightening up again with the spanner
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
I assume you're all talking about bleeding the fronts. I just use a deep socket which fits the bleeder valve. Then I use a small vise-grip to clamp on to the socket to turn it with. I attach my bleeder hose to the valve, run the hose through the socket and fit the socket to the valve, and open/close it with the vise-grip.
IIRC, a normal flare wrench fits the rears.
Paul
Paul
