My rear most spring has pushed through the upper cup and is now about 1.5 inches more extended than the other. It is still tightly held in and has not been making any noise. I have no idea how long it has been like that and it drives and rides well. Has anyone had this failure and can tell me what is involved in the repair? I am still looking for my disc with the manual to look it up but I put it somewhere safe and can not find it at the moment.
Rear Spring Upper Cup Failure
Wayne Roberts
Wayne Roberts
Twin Pinzies
Wayne Roberts
Yes the spring had slid all the way up and it was leaning. Thats how I found the damage. The repair was not hard once the bolts broke loose. SAV had the parts in stock and the whole job took less than 2 hours including clean up. I took the truck out last night and it rode like new. I did do both of the drivers side as the other was worn bad but not quite ready to fail. The pins that come down from the body cleaned up well and did not have much rust on them. What is the repair if these pins were bad? I did not see that they were removable.
Wayne
Wayne
blackstack
Wayne Roberts
