Where is distributor vent line?
I've read several posts about making sure the vacuum line to the distributor is clear but I can't see a line heading to mine, or is it inside the braided cable that leads to the coil?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
vacuum line
Yours is an Austrian spec vehicle and doesn't have one.
Nigel.
vacuum line
Not many differences Robin, main ones being Austrian has fuse boxes, Swiss has thermal trips, different lighting switches and different front indicator lamps and rear lamps, the rest is pretty much the same.
