The Story: Today the Pinz had a hard time starting up (like it was cranking in the super super cold). It was however a warm day today (60°F). I drove it about 4 miles down to the Nut n' Bolt shop. When I came out with the goods the MOST it would do is one or two turns and done. Then it wouldn't even light the dash icons. Fortunately my friend was just down the street at his shop and rolled up with a battery conditioner. We let each 12v charge up for about 15 minutes (40 amp charge cycle) each. Once we got em charged up the Pinz started "ok" and idled happily.
As a test we took a VOM to it before charging and got 11.9v across each 12v individually and 23.8v across the series circuit. BEFORE charging we put the VOM on the 24v circuit posts and with the battery cutoff key ON it read 23.8, as soon as I hit the starter button the VOM dropped to DEAD ZERO!
After charging and getting it started we unscrewed the battery cable connecting the two 12v in series and the Pinz died immeadiately, no attempting, no sputtering, no dieseling, nothing. The instant that the terminal was disconnected the truck died.
Any of your thoughts will be greatly appreciated.
