EFI
M Wehrman
Re: EFI
Post by M Wehrman »
It will be worth the wait.I have odd parts,they're yours if needed. :)
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Re: EFI
Post by Jim LaGuardia »
Mark, We have a complete rocker bar assembly and push rods on the way.
4 rocker arms and bar had excessive wear as well as the push rod ends. The valves would not stay adjusted causing low vac at times, and screwing up my data logs and making way too much valve lash noise.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
prea356m
Re: EFI
Post by prea356m »
Hi
I am following with great interest the installation of this system. I have a Volvo C303 12 volts
very thirsty, as usuall ,so I'm looking forward to see when you've finished the job if it will be a possible reduction in consumption even with a possible increase in power at low revs
Mario
M Wehrman
Re: EFI
Post by M Wehrman »
Just when the wounds were about to heal.......... :lol:
68 Haffy
David Dunn
Re: EFI
Post by David Dunn »
Welcome to 'The Never Ending Story'... :lol:
... wish it to the cornfield
HafWit
Re: EFI
Post by HafWit »
Geez, Dave.....of all people!
I would have thought you were an optimist. Considering the many vehicles you have owned and the issues you have encountered, I would expect you to be more understanding. The unfortunate truth is that the vehicle probably has a lot more mileage than we had anticipated and thus wear was "discovered" in many parts. The good news is that the engine is now working better and data is being collected to optimize the settings. I'm sure that Jim will comment more in due time.
Greg
HafWit
Re: EFI
Finally it is running very good. Had to replace the butterflies with MGB special updated version and bump fuel pressure up a little. I'll upload the image and part # for the anti stall butterfly assemblies with vac popet valve when I get a chance.
I am trying to complete a couple of Pinz engines, so it may be a few days before they are posted 8)
Re: EFI
New engine is running good but a little lean on initial chip. Waiting for new chip, data logs sent..............................
