Washer Fluid Pump
Washer Fluid Pump
When I got my truck the pump worked, but took quite a few pumps to get fluid. Now it doesn't seem to work no matter how hard I much I pump. What generally fails on these pumps? I haven't had a chance to dive in yet.
Re: Washer Fluid Pump
I'll piggy back this thread, mine stopped working last year and I've not bothered to look into it........lazy lazy lazy me.......
I've found that often the rubber bulb dries out, cracks and leaks air so it can no longer create a suction. Same goes for the plastic lines.
I used a generic NAPA 12V washer pump, added a momentary on button and now drive in style
Thanks. I will take a look at the lines first, as I am sure they are easier to replace.pcolette wrote:I've found that often the rubber bulb dries out, cracks and leaks air so it can no longer create a suction. Same goes for the plastic lines.
Did you tap a 12v source?Winter Beater wrote:I used a generic NAPA 12V washer pump, added a momentary on button and now drive in style
yes. I have a 12V system installed for accessories.
You could also check fleabay for 24v ones; sometimes you can find one pretty cheap. I decided to go electric for reliability, the rubber bulb may be simpler, but I think if it was an electric pump it would still be working. The one I found online happens to be off a CAT road grader, I just haven't had time to install it yet. I plan to mount a momentary push-button switch in the hole where the bulb used to be.
Chris.
https://www.supanik.com/pinz
[quote="berger"]Here is a 24v pump for $19.99.
Thanks for the tip!
I just ordered one to replace my tired manual system.
Thanks for the tip!
Cool! Please let me know how it works for you!pcolette wrote:Thanks for the tip!berger wrote:Here is a 24v pump for $19.99.I just ordered one to replace my tired manual system.
Well my pump had a broken nipple. So I attempted a repair will se how it goes.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
I’ve had mine tweaked a few timesmopar wrote:Well my pump had a broken nipple. So I attempted a repair will se how it goes.
Looks to be a fine repair job. How did you do it? Drill and insert the brass looking piece?
