Trying to acertain if the noise from my 6x6 is typical or needs help.
I find when accelerating "on throttle" the rear axles are quiet (it's relative!), and when decelerating "off throttle the rear axles are quiet, but when holding a neutral throttle there is a terrible growl from the rear axles which can be felt throught the body as well.
Is this typical?
Ian
TGB 13 6x6 "grumble"
roobar_and_custard
Re: TGB 13 6x6 "grumble"
Hi Ian,
have you already checked the driveshaft an U-joints ?
You should also check the PTO from second to third axle. The bearings inside are often worn out.
Uli
Uli
roobar_and_custard
Cheers Uli.
I gather that this is not typical and therefore something I can fix.
I took the rear prop shaft off and ran it with only the front rear axle driven, and the noise goes away.
Guess the PTO should be the next investigation.
Ian.
Ian.
