How do i LOWER the k/ph on a sync tool / carbs
Engine troubles? Try here.
Re: How do i LOWER the k/ph on a sync tool / carbs
How about a video?
http://www.youtube.com/watch?v=qkDN8g1uUhY
The rear carb started dripping fuel this time. Looks like i need to adjust the float valve there. Would that do it?
Post by Jim LaGuardia »
Before continuing, replace the leaking float valve. Pump rods are 80mm when set correctly.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Id love to Jim, but i cant...
Tried 3 different valves, and all 3 sizes of the shims combined and it still drips, but only when the engine is running. It stops dripping immediately when i shut it off. Any ideas?
float screws are solid by the way.
