Intro from Malaysia - WR7002 - C304
geckoadventure
New Zealand
Re: Intro from Malaysia - WR7002 - C304
Post by geckoadventure »
Garrycol wrote:
geckoadventure wrote:A power steering unit from USA was installed I believe rock climbing conversion company.
I do not have the power steering unit website I used to have it i will get it again.
Thanks for that information - if you are later able to provide a link or advice on the actual power steering unit I would appreciate it.
Garry
ok after much searching through old sms's I found the link
https://sweetmfg.biz/pages.php?pageid=12
then these
https://sweetmfg.biz/home.php?cat=39
i recall mine is the one with the 200 valve.
Model SKU: 303-33200
good luck hope this all helps.
Garrycol
Post by Garrycol »
Your a champ - that is great - thanks a million.
Looks like a very cost effective solution.
Garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
geckoadventure
New Zealand
inspiration the team havast Volvo C304.
http://www.youtube.com/watch?v=GrZisvDrYEk
Garrycol
Post by Garrycol »
then these
On researching further what you have installed is a servo which as I understand regulates the amount of fluid that goes to a ram or power steering unit depending on the arrangement. But from reading your post I take it that you are using the servo as the power steering unit.
Is that correct or have a I missed something.
Sorry to ask so many questions but I have been looking for a solution for my vehicle for a while and this looks like it might be it.
Garry
1957 Landrover 88"
roobar_and_custard
Post by roobar_and_custard »
Hi Garry,
Or you could try these...
http://www.woodwardsteering.com/
Not sure how you would go with engineering approvals when cutting up a column and inserting a powersteering servo.
Good luck.
Ian
geckoadventure
New Zealand
3 September 2014
Ok so have a few spare days after breaking down in the jungle about 20 days ago and had to wait 2 days for parts and got back to work on the wednesday so immediately went on 2 weeks compulsory leave due to our leave policy.
Today popped up to work on the Volvo before its stripped.
Cut out the 12mm round bar for the tie down points and some loops have 3-4 to cut out tomorrow and then we will weld them in. 13 done 3 to go in the morning.
Last item to do is to fit the step release whichis inside the cabin where yellow line is where the internal step release will be placed tomorrow.
Details - side bars all fitted now can remove panels and have it 1/2 opened at the rear or completely paneled up. Front two uprights on the bull bar fitted. New rollcage rules might make my external cage legal here now :)
Tool box in the front grill is visible. Some holes to fill the painter will advise how to fill weld or braise or hole sealant.
Top view looks cool only exhaust exit bit to do.
Seats all sitting in place nothing to do except bolt down.
37" Trepadors are going to cause an issue we need to fit them tomorrow and look at the offset they are going to touch the front guards.
KInda happy - more reporting later on Friday.
I'd take it easy when you drive that thing later on. Extra power with the extra tire size/weight, plus extra truck weight, is going to push those axles/hubs to the limit.
Are you going to keep the outer seat bottom/bolster stock? It makes it a real bitch to get in and out of. I tested this once myself and went with another seat because of the limited room and height you are dealing with.
geckoadventure
New Zealand
VinceAtReal4x4s wrote:I'd take it easy when you drive that thing later on. Extra power with the extra tire size/weight, plus extra truck weight, is going to push those axles/hubs to the limit.
If you have any advice on the axles/hubs limits (bearing fixes/upgrades) I would appreciate I do not want to break one of these in the middle of nowhere I just lost 2 days off work as I busted a wheel off my trropy twice and had to get spares driven in and both resuce vehicles broke - story of the trip later.
The seats may get the bolster removed I will try them today again to get in and out of then I can see about getting them fixed before I put it back on the road.
geckoadventure
New Zealand
4 September 2014
Finished up the top hatch locking tabs. Welded in the tie downs points and finished the fold down steps locking pins.
Then it was the time for the strip. All the bolts are undone 8 to go in the morning to lift the rear out.
The doors have an internal rust issue to be dealt with
Front cage off and the wiring loom stripped and labelled.
All the doors frames etc removed
Side view
Tomorrow the LIFT off.
I dont know what you can really do outside of having custom shafts made or at least having everything cryo-treated and/or shot-peened... or use 35's instead of 37's but I understand you have mud issues unlike most of us would ever encounter. Definitely avoid dumping the clutch, ever.
Also you can not beat this CV joint deal for some extra insurance. http://www.rcvperformance.com/product-d ... ku=174-VRT
Are those doors rusty? That looks like the wax-oil treatment a lot of Volvo's have.
geckoadventure
New Zealand
VinceAtReal4x4s wrote:I dont know what you can really do outside of having custom shafts made or at least having everything cryo-treated and/or shot-peened... or use 35's instead of 37's but I understand you have mud issues unlike most of us would ever encounter. Definitely avoid dumping the clutch, ever.
Vince
A friend got some custom made portal gears and shafts made in USA I will chase him up.
There is rust it was in a pile in the bottom of the channel. A fist full of rust pieces from isode the door yet there is no visible sign of rust. There was sponge inside the door also a moisture catcher.
The doors are to be split and antirust paint applied.
My style is not to dump the clutch even in COMP I do not dump the clutch.
Thanks for the link for the CV joints I will look at and find a cost.
Except in this vehicle - lol
[youtube]CWBRMV6oq3w[/youtube]
http://www.youtube.com/watch?v=CWBRMV6oq3w
geckoadventure
New Zealand
5 September 2014
Continuing the stripping today all stripped and all touchup welding done and then we discovered that 2 braces had been missed on the rear body and the 6 contact points with the cabin needed more work.
Damn fit the cage back on and redo the welds took us an hour to fit it properly to effect the repair.
Time for home to repair the busted CV joint on the mighty troopy they had one set of welds left to do.
Monday finish the remaining touchups on the body
Tuesday off to the paint shop for the sandblasting and undercoat.
The gears in the hub were custom made? That sounds very expensive to do correctly.
geckoadventure
New Zealand
then these
Garry
This very same solution is being used in a 400bhp (at the wheels) 2WD Landrover so we know it works. Yeah the LR is kinda FAST lol.
geckoadventure
New Zealand
roobar_and_custard wrote:Hi Garry,
Good luck.
Ian
We ain't telling them what we done to the steering.
