The diagram itself, the picture is correct, but when youre holding the relay in your hand you can see the numbers are switched.edzz wrote:Darmbruster1 wrote:Hi. This swiss schematic has been useful but i have found an error.
The Battery Switch Relay diagram: the picture is correct, showing the ground on the bottom left terminal, but the terminal numbers are switched. 85 should be 86 and vice verse...
Based on my Swiss manuals you are in error.The color drawing is correct. Sorry.
One thing i cant find on the diagram is the three relays behind the driver's seat...what are they? I have a blue wire running from the center one, down to (the vicinity of) the battery switch relay... its a female with a broken spade in it... its a mystery
-Dave
