So first: the articulating map-reading lamps in the back! It took reading the operating manual cover-to-cover, but I finally realized that they are designed NOT to work unless all three doors are closed. GREAT, I though, and rushed out to try it. No luck. So then I look and see that one of the leads to the rear door switch was not connected, so the circuit wouldn't complete. Okay, so I re-attached it. Problem solved? Unfortunately, this didn't do it either.
Any ideas on what I might be missing? Yes, I've turned on the main power that activates the rear dome lights first.
