I have a 712M which I'm in the process of restoring and then adding a few creature comforts to. I'd appreciate any ideas on what works (or doesn't).
Thanks in advance!
Sent from my SM-G981B using Tapatalk
Restoration & upgrade ideas
- Hotzenplotz
Re: Restoration & upgrade ideas
well, a quick review of the mods I've done:
- power steering
- tubeless tires on Ford rims
- LED headlights
- seats from a Smart minicar
- Pertronics ignition and civilian wires / spark plugs/ distributor cap
- machined off 2 mm from cylinder heads to increase compression when running with 95 octane fuel
- swapped the hi/lo gearbox for a 710 model
Albert
Albert
The bigger "comfort" items that I would recommend...
- Power steering (EZ)
- EFI (Goatwerks)
- 2.7L motor rebuild (Goatwerks)
- SAV Power brake booster
- Webasto or clone heater (depending on your use case)
Jason @battlebornpinzgauer
