Do door hinge pins from side doors match front door hinges?
Jake2015
Post by Jake2015 »
I have a stuck hinge pin in one of my front doors that has resisted all attempts to remove it. I’m about ready to remove via destructive methods, but wanting to have a replacement pin. I haven’t found hinge pins on SAV for the front doors, only the K side doors (part number 7131760151). Does anyone know if this would be the same pin as used in the front door?
_________________
1977 Austrian 712K
http://www.swpinz.com
Facebook: Southwest Pinzgauer
Hotzenplotz
Austria
Re: Do door hinge pins from side doors match front door hing
Post by Hotzenplotz »
Jake
The pins are different
front door pin 7111760461 diameter 8mm length 61,5mm
side door pin 7131760151 diameter 6mm length 45mm
you can find all parts on www.puch.at, the manufacturer's site
Albert
whitesik
Post by whitesik »
I have found that lots of PB blaster and an air powered impact hammer with pointed bit to be quite effective and actually preserves the pin. However, while out, I would replace them. They are readily available.
75 Swiss 710K
W9YG
Jake2015
Post by Jake2015 »
Hotzenplotz, thanks for the information.
Whitesik, I have tried that, but perhaps I need to try again.
_________________
1977 Austrian 712K
