Headlights
jgeesen
Headlights
Post by jgeesen »
I know this has been gone over before, but it's been a while...and I wasn't paying much attention. :oops:
I had one of my SAV non-DOT (55W/75W, if I remember right) bulbs go out on low-beam. I may just order another pair of hi-output bulbs, but this may be a good time to upgrade the whole giddup.
So, what is the scoop on aftermarket headlights? I would like to keep the little bulb in the reflector - great for driving thru camp at night without aggravating the natives.
Price is an issue - I am not looking for an exotic upgrade.
Does anyone run aftermarket (reflector/lens) headlights? How do they compare to the stock units, assuming you would have before and after experience?
thanx
John Geesen
skybarney
Post by skybarney »
I spent around 100 dollars going to a Hella upgrade. Well worth it.
Tim Nelson
"ParaPinz"
jgeesen
Post by jgeesen »
That price sounds tolerable. Is that with new bulbs and reflectors? Part #'s? Do they have a place for the super low-beam bulb? Where did you get them from? Links?
Is that enough questions?
thanx
jgeesen
Post by jgeesen »
Help - need more info
2012
Post by 2012 »
i'm a little lost here. both the sav $115 and $129 headlights are hella halogen. the lights you got from sav WEREN'T those hella's?
i know those hella reflectors well - they are the most wonderful housings/reflectors in existence. maybe you could buy a couple clear or yellow led marker lights and mount them underneath to replace that little bulb that resembles a 60's vw.
hmm. on the side: do h4 bulbs fit in the standard pinz reflectors?
John
Cibie are available from these people, and with 24v bulbs. and with the parking lamp in the reflector
http://www.cibieusa.com/cibie_main_frameset.htm
I have been running Cibie for over 30 years. Currently have them in 2 LRs and a Ford F700
Dave Dunn
Scott
Post by Scott »
John,
I bought my Cibie E-codes from the same link that Dave posted above. If I remember correctly, the price was camparable to the Hellas that you can get from the Pinz parts guys. You can get the Cibies with or without the little city light in them. If you get them with it, you'll need to cut a small notch, maybe 1" x 2" in the headlight bucket to allow for enough room for the city light bulb. This is because on the Cibies, the city light is positioned farther below the regular bulb than it is on the original headlights. I'm plenty happy with mine.
Scott
1974 Pinzgauer 710M
2012
Post by 2012 »
cibie! i didn't know they still existed! 25 years ago they made the most amazing fog/cornering light - the spread was over 180 deg and had a totally horizontal and totally BLACK AS NIGHT cut-off. it looks like that's what they call the "charlie" now.
does anyone know how cibie's 7" headlight lenses compare to hella's?
2012 wrote: does anyone know how cibie's 7" headlight lenses compare to hella's?
Hella wins to me. They also build the best industrial/commercial lighting available.
Or look at what my 303 has on it. Headlights with beam altering/focusing lenses is very outdated technology. Look for free-form reflectors with 100% transparent lenses. And if money isn't an object, you might look at an HID driving or fog pattern kit for off-road and/or high beam supplement. 24v ballast kits are available and the light is beyond belief.
Whichever way you go will be a huge, and I mean huge, improvement over those stock pieces of junk. (which I strongly feel are actually dangerous and thus, useless)
HafWit
Post by HafWit »
Dave,
Have you replaced the dim lights in your Haflinger? If so, what did you go with?
Greg
HafWit
milesdzyn
Post by milesdzyn »
I'm with Vince on the HID's they may be more expensive but consider this. Standard off-road lighting is a major draw on current, and with the 35 amp alternator of the Pinz you will really be taxing the whole recharging system. So add up the cost of a new Alternator, Voltage regulator, and 2 Optima batteries. The HID's use little power after initially turning them on, and are tuff enough for Off-road use. Just my opinion but I think they are the way to go. Plus don't forget the tow bill if the Alternator goes out on the trail.
Miles
2012
Post by 2012 »
vince - i looked at your truck's bom and it didn't state a mfr or part number or anything for the headlights. help? looks like a gr8 idea.
miles - roger that
jgeesen
Post by jgeesen »
Thanx all for the input - I'll be doing some more research.
