Overhauling the jack
Has anyone done a jack overhaul? I got a leaker with my Pinz and want to see if "domestic" seals and o-rings will work. Any info. appreciated.
1975 710M
Back to the subject
Loyal posted a link in the yahoo groups a couple years back(ain't archives great!), to a place in Orange county Ca.
http://www.jackxchange.com, I believe then the price was around $89-$125.
Not too bad
Not too bad
http://www.swpinzgauer.org/html/local_resources.html
near bottom of list is the jack place I used flat rate $75.00
I took my jack to the local hydraulic shop. They looked it over and went for their catalogs for me to pick out a new one. I tried explaining that it wasn't a stock jack, and I doubted that anything in their catalogs would be an acceptable replacement. They were quite insistent that the Pinz jack was a common, everyday hydraulic jack. We never got to talking about what color to paint it...but needless to say, my jack is still broken. I do have a $30.00 box-store jack that has been more than adequate in the meantime.
-Evan
-Evan
The 710M is around 4,400 pounds; the payload is around 3400 pounds. Call it 7800 pounds total. Say all the weight is on two wheels, worst case, so around 3900 pounds per wheel. That puts the weight at about 1.95 tons (US).
Finding a jack with a two-ton capacity is a no-brainer. Finding a jack with usable extension is the trick. I have used my aftermarket bottle jack with a stack of wood under it to give it enough lift. It works, but is not as safe as the factory jack would be with the saddle on the top and the rocking base. Especially on uneven terrain. It would not be that hard to modify an aftermarket jack for these feature, given modest welding skills. I personally do not think $200.00 on repairing the factory jack is a priority.
The bottle jack I have is rated for 12 ton (24,000 pounds). Sadly, it is painted black; not blue - but I have learned to adapt. I picked this jack because it has a large base (for stability) and is taller, giving it a greater lift distance than the tiny jacks.
-Evan
-Evan
