so/cal pinzgauer?
pdxdave
so/cal pinzgauer?
Post by pdxdave »
Long time-no post from me! So I'm trying to get past the post partum depression of selling my beloved 416 mog and I find myself looking at a pinz 712 here in town. It has "so/cal pingauers.com" on the side. Who is this and are thay still around? The name Eric something cam up.
Any input would be cool.
Dave in Portland
So Cal Pinz was restructured and moved, name changed to Pinzwerks and then closed in April.
pdxdave
Post by pdxdave »
Thanks for the reply Jim, I'm just trying to find a little history on the truck before I do something completely impulsive.......
Dave
pdxdave
Post by pdxdave »
Wow, 87 views and only one person has any info on Socal pingauers?!?!
That sure dont say much for them........
Thanks again everyone.
Dave in Portland
Lightningpinz
Post by Lightningpinz »
Hey Dave a lot of people know of and about So-Cal, but refrain from posting possibly due to the rules of the board.
Rules? I don't care about no stinkin' rules...
But I am a Gentleman :roll:.... fit waders now
Lightningpinz
I used to be a gentlemen, but the Lovely Linda didn't like me in their clubs. She would rather I get in the Pinz than a Gentlemen's club. :shock: So here I are. :twisted:
I don't need waders I use the Cheech and Chong method of identification.
I'm not here.
Isn't great to go a place where everyone knows yours name...
and the way they lock the door , shut the lights off and pretend no one's inside :wink:
Lightningpinz
They may all know my name, but when they lock the door and turn out the lights it's a great place to be alone and gather my thoughts. I get a lot of peace and quiet. Kinda like the Fortress of Solitude.
pdxdave
Post by pdxdave »
Lightningpinz wrote:Hey Dave a lot of people know of and about So-Cal, but refrain from posting possibly due to the rules of the board.
I respect that and if anyone has the desire to e-mail me direct, off-board, That would be great.
dave@gpimports.com id the easiest way to get in touch with me.
Thanks again
Dave in Portland
M Wehrman
Post by M Wehrman »
I guess this is one of those times when " you had to of been there". :roll: :roll: Kinda like the Code Talkers of WW2. 8) 8) .
Just feeling left out of some juicy "tidbits",after all that what makes Soaps and Desperate Housewives all sooo interesting! :twisted: :twisted: TTFN,Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
pdxdave
Post by pdxdave »
So heres the specs and details.......1973 712M 6x6 Steyr Daimler Puch Pinzgauer / Swiss Military
Factory rebuilt engine
Beck distributor cap adapter for performance spark plugs and wires
Pertronix pointless ignition upgrade
Cruising speed 65 to 75 MPH
Painted front and rear springs on new upper and lower spring cups and spring centering rings
New flexible brake lines
Rebuilt brake master cylinder
New Clutch and pressure plate
Upgraded high speed 5 OEM ZF transmission (with 285 75 16 BFG AT = 70MPH @ 3300 RPM)
Balanced external drive shaft with OEM universal joints
Balanced internal drive shaft, resealing and complete bearing inspection by So Cal Pinzgauers
7 - Custom modified 8" wide steel wheels by Beck using stock centers with US DOT approved outer hoops which maintain the stock 6 5/8"back set and add 2"of front offset
7 - BFG 285 75 16 (33") AT tires
Custom thrust generator power steering with furnace braised extended steering box
Rancho steering stabilizer
Fully sound deadened interior using Cascade Audio Engineering VB3, and other materials
Custom powder coated interior door panels with upholstered, padded surfaces
All body hardware removed and replaced with stainless steel hardware threads tapped, and coated with nickel based never seize (factory spec)
2 re-upholstered and padded stock front seats with powder coated gray frames and all new rear rubber straps
6 re-upholstered and padded stock rear jump seats with powder coated gray frames and Arma coated Polyurethane 5 bar backs (flip down to form flat bed)
Custom rear cab bulkhead with sound deadening, Arma coated, speaker enclosures, audio amplifier, Sony CD changer, tinted sliding glass window and enclosure for new Eberspacher heater
New Eberspacher heater with computer controlled thermostat and timer
24 VDC to 12VDC reducer/battery charger
4 Optima red top gel batteries, 2 for 24 VDC and 2 for 12 VDC in stock battery enclosures
Sony stereo receiver with remote
Sony CD changer
2- Rockford Fosgate 10"woofers, 2- 4" Rockford Fosgate Mids
Lower body Arma coat polyurethane coating inside and out
All gray colored parts are powder coated
Hella H4 Lights
All new factory felted window channel
Factory Turbo Diesel larger rear tail lights with reverse lights switched off transmission
Custom steel powdercoated dash panel with electronic VDO speedo, Tachometer and fuel gauge
Custom SNFR front BrushGuard
Custom SNFR fuel tank TankGuard
Custom SNFR rear door mounted wider spare tire mount for full sized 8"rim and wider tire
Arma coated side rails
TechnoTop fiberglass removable front Cab roof with removable sun roof
New Steyr factory production tan rear soft top with heat-sealed seams
At this point we're still haggling $ but the range is LOW 30's
Am I in the ball park?
Dave in Portland
Pinz Enthusiast
so/cal pinzgauer?
Post by Pinz Enthusiast »
Wow what a list of equipment, sure wish mine was decked out like that, but from what I can tell it sounds like your describing the Mozo II pinz, I saw Mozo I listed on consignment at SAV for $54,000.00 or so, so if you got $30k to drop on a pinz that would be a great one to go for, as far as your earlier post about So/Cal and some guy named Eric, I think your talking about Eric Purdom, think he is the guy who built the Mozo Pinzies, I am sure others out there can correct me on this, good luck with your negotiations and great wheeling.
Eric
Anaheim Hills, Ca
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
pdxdave
Post by pdxdave »
I came out of my 416 in good shape and 30k is a realistic # if the truck is worth it, My instinct here is this is a solid truck and was put together right frommthe begining.
Dave
