Tyre Sizes
SAM. C.
Tyre Sizes
Post by SAM. C. »
Hi all
What are the widest tyres you can fit on the standard Pinz rims? And has anyone widened rims to fit on wider tyres?
I dont know if this is even possible (widening the rims) or is it a no no?
Any advice would be appreciated.
Sam
Profpinz
Post by Profpinz »
G'Day Sam,
How goes it?
I run 10.5" wide Simex on standard rims without any problems!
1997, 718 6X6 Pinzgauer
pinzwheeling
Post by pinzwheeling »
Sam,
If you do a search for tires, you will find tons of information regarding tire size and rim size.
Best regards,
Michael
Michael
email: rosenblumm@gmail.com
SAM. C.
Tyres
Post by SAM. C. »
Hi Peter
Yes it is going really well. I am getting to know my way around the Pinz now. I must admit that after working on other vehicles the Pinz is a joy to work on and metric :D .
What I am after is some of the widest tyres I can get for sand. The 245s are about 9.6 inches so it is Ok to put the ones you mentioned on Standard rims is Ok?
I just asked at my local Cooper dealer and they told me not to go for anything wider than a 245 on a 6.5" rim but I guess they are just being cautious as they mentioned uneven wear but the camber on a Pinz must cause uneven wear anyway.
Thaks for the advice.
Sam
M Wehrman
Post by M Wehrman »
I find it's not the size of the tire but the rim design....low pressures seem to be a problem with stock rims breaking beads. If you don't have to air down the sky seems to be the limit!
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Kiwibru
Post by Kiwibru »
285's on stock rims here. Lots of extra rubber to move down the road which really drops the mileage! Lots of go in the mush though!
1975 710M
Erik712m
Post by Erik712m »
I am running 33*12"50 on after makert rims on after market rims. But I still have a hard time in the sand in some areas of kansas we have a sand that is very fine dirty thirty sand I have been told even My brothers Lm002 has a hard time.
AK NIMROD
Post by AK NIMROD »
when i bought mine it had 35 x 13.5 X 16 on it i was not comfortable with that ( they recommend 10-12 inch wide wheels) i had 10" wide ones made. and have those on it now but probably would not get wheels made if to do it again and would have sold bigger tires and stay with smaller ones. just bought trXus MT's 255 X 85 X 16 when i was visiting Denver.
big tires will be nice when off roading in the muck thou. there are pictures of both in various threads here
SAM. C.
Tyres
Post by SAM. C. »
Thanks Guys
I have had the problem with a tyre coming off of the bead at reduced pressure so I wanted a bit more surface area without lowering psi too much.
I am interested in AK Nimrod’s comment. Why would you not stick with the wider tyres? Do they cause a lot of drag and what are the drawbacks of using them?
Thanks again
Sam
AK NIMROD
Post by AK NIMROD »
seems to be alot of drag, for on road use noticeable decrease in power, still gets up to speed but slower to get there. the guy that had them on the 6-1/2 wheels never had any problem and would air them down to mid teens if i remember right.
the reason i guess mainly is before spending $900 on custom wheels again i would have gotten other tires. the big tires look nice and after snow is gone and i can use them off road i might change my mind.
