windshield removal
windshield removal
I'm not able to remove windshield
Pinz: 710 m, 710 ms, 710 k, 712 m fla, 712 k, 716 m, 718 m san, 716 k, 718 rehinbraun
Haflinger: 700, 703
G: 250, 270, 400, 350
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Haflinger: 700, 703
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Remove the bolts along the top, 2 on either side above the door frame and the ones on the lower tabs above the dash, and should come right out. I had mine off about 4 years back. Pretty straight forward on removal.
Dave Dunn
Dave Dunn
Thanks Dave,
but pls be more clear as my english is not so good: what do you exactly mean with "the ones on the lower tabs above the dash"?
I removed the top and then the 6 screw on the vertical holding brackets, 3 on left and 3 on right site of windshield frame (even if the lower one on each side seems useless).
The frame sways a bit if pushed forth but does not come out if pulled and I cannot find other screw/bolts.
Help!
Ciao
Gunipinzmutt
Help!
Ciao
Gunipinzmutt
Haflinger: 700, 703
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Haflinger: 700, 703
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Gunipinzmutt
Send a email to me at dsd277@sbcglobal.net and I can send a pdf from the parts manual. Hopefully from the pdf it will be obvious how the frame is held on. There are only 2 bolts holding the frame at the bottom, and maybe the bottom rubber seal has melted a bit and is holding it all together.
Dave Dunn
Dave Dunn
