I probaably should have not touched it, but I did. The heater hose from the heat exchanger to the forward cab heat outlet is disintergrating. Is there a source for this cloth spiral wound hose?
Napa only has 2.5 and 3.5 inch hose and this stuff is approx 3 inch.
I am planning a trip to NWMF and leaving San Diego 8/4 for the trip, planning to see a few sights along the way.
Any help will be appreciated.
Morris
heater hose
I got mine from here.
http://www.aircraftspruce.com/menus/ap/ducting.html
Besides the ducting they have lots of 24 volt stuff
Bernhard
1975 710K
2013 Tacoma TRD 4X4
1975 710K
2013 Tacoma TRD 4X4
Metric heater hose
Another source for metric H.D. rubber heater hose is McMaster-Carr. PN 53335 K13 is 80mm, heat resistant and very heavy duty. You can wrap the portion near heat sources with aluminum tape. They also carry a un-slit foam rubber insulation that slips over the hose just fine. That is PN 4463 K145. A must have for the more Northern climates!
1975 710M
Replaced all my hoses. I used http://www.aircraftspruce.com/menus/ap/ducting.html
Great product, great service.
