Now will the distributor rotor point to the mark in the dist. at each one of these stops as well (give or take a few degrees based on the timing)? Seems like it should to me. We are setting the valve clearance at the ignition point for each cylinder, right?Step 4. Rotate the engine one half turn in the direction of normal rotation (the way it turns when it runs), until the chalk mark is aligned with the pointer and adjust the valves of #2 cylinder. Rotate another half turn until the timing mark is aligned again and adjust #4 cylinder’s valves, another half turn and adjust the valves for #3 cylinder.
I'll be checking the head bolt torques, replacing the gaskets with the rubber ones from EI, checking the timing, checking the plugs, and hopefully calling it a day.
