4th Gear Syncro?
Posted: Fri Aug 17, 2007 10:53 am
by loyalp
On my drive home this weekend after hitting the fireroads all day at lower gears, I had a bit of trouble getting into 4th gear on the paved road. It didn't grind or make any noises. Just would not go into 4th gear, like something was stuck in the linkage.
I've checked the linkage and it all looks okay....
Do I need to start worrying about a big expense?
Posted: Fri Aug 17, 2007 3:13 pm
by Jim LaGuardia
Might be a broken fork pin.
call me after 6pm and I'll walk you through it(909)881-8623
Posted: Fri Aug 17, 2007 3:28 pm
by PinzEOD
Check your heater hoses. I've had mine come loose and bind up the shifter.
Posted: Fri Aug 17, 2007 6:05 pm
by loyalp
I took another crawl underneath with some better lighting and a camera.
The linkage is pretty wet, and I am suspecting this may just be that I've lost the gear oil from the gearbox...
[/img]
Posted: Fri Aug 17, 2007 6:37 pm
by todds112
Mine looks like that too. I've got the replacement seals sitting on my desk waiting for the time to be installed.
