Bad voltage regulator AND alternator? Do they go together?
Twin Pinzies
Post by Twin Pinzies »
I usaully do my own wrenching but I brought my 710M to the mechanic to diagnose an over-charging electrical problem. He tells me to replace the voltage regulator and the alternator. This seems weird to me. Is he just guessing at the problem and having me replace un needed parts because he is too lazy to properly diagnose? A new alternator is $1,500!!
I'm sure that I if I do replace both, it will solve the problem, but could it just be the regulator?
Very seldom do they fail together. If it is overcharging, the regulator is bad, 28.8v is max allowable output.
If you do need an alt, I can get them rebuilt and rewound to 50 Amps for a very reasonable amount. I also have a good spare. PM or e-mail me if interested.
TurboJim
Post by TurboJim »
if its overcharging replace the regulator first 35 bucks or so
It is only air and fuel ...For every 1 lb boost will gain you 10 % displacement
Erik712m
Post by Erik712m »
TurboJim, were did you find a Regulator?
TurboJim
Post by TurboJim »
sav had a used one for now
