Spare Tire Cargo Rack
Does anyone know if there is a cargo rack that will mount to my spare tire?
Don't be afraid to do something completely Outrageous. 73 712m Tan, 73 712m Green
Re: Spare Tire Cargo Rack
Never seen a stock one but, i bet someone can make one.
There is already a lot of weight on that door with the tire.
I have a box mounted on the inside and it does add weight.
Ya I need more storage for a cooler.
Grab the tire mount that attaches to where the main ant mast is positioned (center above cockpit), then mount your cooler to the back door.
So...you're going to mount a cooler to the back door...and leave your beer exposed to the world?
Sounds risky to me.
Sounds risky to me.
krick3tt wrote:So...you're going to mount a cooler to the back door...and leave your beer exposed to the world?
Sounds risky to me.
- GenevaPinz
Quadratec sell the toolbox version... beer cooler is an even better idea!!audiocontr wrote:Now what would be pretty nifty is if you took an old gas can or two, CAREFULLY cleaned it out and cut it down the center. Insulate, toss a hinge on it, and turn THAT into a cooler!
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
this is the route to go
http://www.quadratec.com/products/14072 ... lemerchant
edit: just noticed we posted the same link...fine minds and all that.
Thanks for the killer gas can idea . I have a coleman cooler From the 70s so i guess i still need a Rack to Hold It??
Why not re-invent the wheel?audiocontr wrote:Now what would be pretty nifty is if you took an old gas can or two, CAREFULLY cleaned it out and cut it down the center. Insulate, toss a hinge on it, and turn THAT into a cooler!
They're call mermites. ... exactly as you described. Fits perfectly into a gerry can holder.
But back to topic, try not to add any additional weight to the back door, they are already weak. The TDs have a swing out tire carrier with the rear door mounted to the carrier.
NICE!
This is what i like but im not sure it will fit?? http://www.quadratec.com/Assets/Images/ ... 778-lg.jpg
I am looking at your avatar and see that you have a 712, is there no room inside for the cooler? Has the bowling alley and
pool taken it all up? You are really going to put pressure on those hinges with a tire mounted anything.
I do tours for wineries and breweries and carry passengers in the back and have no room for wine glasses and beer mugs.
Winter Beater
David, is the Mermite a stock item as a gas can? Or did you copy the MIL version? I like, and think I need one
