I was wondering if someone could identify this heater? Is there a thermostat adjustment on it, and is this cap right for the heater, cause it rattles when not pushed down tight.
Any info is greatly appreciated. (Pictures taken on my Tab)
Yes exactly:milesdzyn wrote:Looks like a Benmar Made for the US Military back in the 70's but there were other manufactures that made a similar unit.
Miles
djw wrote:Yes exactly:milesdzyn wrote:Looks like a Benmar Made for the US Military back in the 70's but there were other manufactures that made a similar unit.
Miles
http://www.ebay.com/itm/BENMAR-AP-2030- ... 7675.l2557
The heater is switched on the dash, so I am not sure what you mean by controller...I will look under the dash to see.audiocontr wrote:Show us what your controller looks like please. You should be happy that your truck has that mod. Good stuff!!
Jimm391730 wrote:Since the fuel usage is so low, any tiny leaks in the fuel line will allow air to be sucked in instead of fuel - no fuel, no heat. Try putting a temporary fuel source at the same height as the pump; this will tell you if this is the problem.
Thanks! I would appreciate the schematic!Thomas-E wrote:Berger,
I'm running one of these Benmar heaters, fairly happy with it.
I can email you a copy of a control circuit schematic.
When you go to start mode (low) it may take a minute, be sure that your external
fuel pump is primed first. If the heater glow plug/ignitor is working you should see
some vapor coming from the heater exhaust. Check with your hand to see if the
exhaust is warming up. If not you may have a defective ignitor...I had one fail!
Some parts are hard to find, including the ignitor. A suggested fix it to remove it and
replace the ignitor heating coil. Get an automotive cigarette lighter and use its' heater wire
to replace the broken one.
Give me a little time and I may be able to find the manual.
As far as parts are concerned these are still found on ebay. Two types - the Heated Air type
which were used for interior heating and a liquid heater for engine preheating (it uses most
of the same parts).
Yes, on high it does sound like a JET ENGINE.![]()
I bought a spare heater for parts from a gal in Toronto a year ago.
