AUX Heater in a K model
norcal pinz
Post by norcal pinz »
Image How much fuel does this heater burn does anyone know? like in gallons per hour?
710M 1972
710k 1974
Re: AUX Heater in a K model
Generally, these heaters don't use much more than 1 quart per hour, often less.
Between 6 and 16 hours per gallon per the BN4 manual.
norcal pinz
I was also wondering were these heaters meant to be used while driving down the road ? or is it only for when your parked ? and i heard they only work if you have more than half a tank, so how does the unit know how much gas is in the tank ?? :)
710M 1972
710k 1974
I have heard (not first hand information) that some trucks used a "T" in the engine fuel line (before the engine fuel pump) to supply fuel for the heater; this could conceivably drain the tank when parked. IIRC this was discovered because the T and/or other fuel lines had small cracks that would let the fuel pump drain when not running and making starting difficult since the pump was not primed.
I have also heard that other trucks (probably set up from the factory for the heater) have a dedicated fuel pickup tube in the tank that only went about half way down so the heater could not empty the tank. This would always leave some amount of fuel available for the engine.
I have never heard of any prohibition to using the heaters while driving so I guess they could be used while stopped or in motion.
djw
Post by djw »
This is the case with mine when I traced the fuel line debugging it last month.
One of the first tips on a non-working heater I found in heater troubleshooting docs is to make sure your tank is not below the heater's dedicated fuel pick-up. I guess it is up to the owner to figure out at what level the heater's fuel pick-up ends.
The book fuel consumption on mine is .47l/hr at maximum, and .13l/hr at low, which works out to .124 g/hr on high and .035 g/hr on low. Seems a tiny amount to me but that's what it says and a lot of heat before you consume a gallon of fuel.
Roverchef
Germany
Post by Roverchef »
I use mine instead of the "Dash" heater. It seems to heat alot better then the one in the front. I have left it running overnight a few times while I was camping in the back with no issues in terms of fuel or battery consumption in the morning. Insulating the inside of the Pinzy makes a huge difference too. I did find out that it heats alot better when you replace the fresh air duct with a solid panel one from an M and just remove the extra ducting to give it room to suck in "Cab" air. I know you can close the fresh air duct but mine seemed to collect snow/rain even when closed so I opted to seal it up with the solid paneled one. Hope that helps.
BobbyD
Post by BobbyD »
My '71 710K heater is "t-d" off of the fuel line. I suspect it could drain the tank.. I have never ran it more than an hour. This is a result of living in San Diego.
1971 710K S
N2PNZ
:idea: BN4 users please periodically check the fuel regulator for weeping/leaking.
I have 2 trucks here with leaking regulators that could be fire bombs. Have not yet found a source for regulators, but fuel pumps are available on ebay in US(nevada)
Stekay
Post by Stekay »
Jim, if possible, could you please post a pic or describe the location of the fuel regulator?
norcal pinz
just to be clear the heater in the picture is NOT a BN4 model right ??
710M 1972
710k 1974
That is a BN4 in the picture, the regulator is obvious as soon as you take the top cover off. It is silver and the fuel line connects to it.
crcpinz
Post by crcpinz »
How would one go about disconnecting permanently the fuel hose that goes to the heater? I am concerned that I might have a small fuel leak there, and don't plan on ever using the heater.
Si vis pacem, para bellum
1976 710K
Follow the fuel line back to the tee and block it off, then remove the inline fuse from the heater under the top cover.
You could always sell the heater since you do not intend to use it. Surely there is some other pinz part, that is to you, more important
