Rear door lock on a "K"
mm58
Post by mm58 »
Not referring to the keyed lock, but rather the "push-pull" knob next to the rear door handle on a 710K, I'm curious to it's original designed usage concept.
It's sort of a lock, but not really.
How was it used in the military on a practicable application basis?
Re: Rear door lock on a "K"
The half-door on the M has the same push pull lock. Personally, I think it is there so that the door doesn't pop open. Imagine if a load shifted in the back and slid back towards the door. The simple latch mechanism could pop open, whereas the pop-lock ensures it stays closed.
Berger is correct, Page 68 in the Operators Manual.
Also for the front and side door locks see my post in this thread.
viewtopic.php?f=17&t=4894&hilit=door
westernair
Post by westernair »
funny thing about that chain on the spare. I owned my truck for a year before the light bulb went off in my head telling me what it was for.
Sometimes my crayon can be pretty dull. :?
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
mm58
Post by mm58 »
As long as we're on the subject of unique features of the PInz... how about that little hand painted yellow dot on the left side of the dash housing.
That mean anything? e.g. some kind of mod or upgrade has been performed?
mopar
Post by mopar »
mm58 wrote:As long as we're on the subject of unique features of the PInz... how about that little hand painted yellow dot on the left side of the dash housing.
yeah I've been wondering about that also!!
and now my newest pinz has a blue dot near the auction number
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Just installed the rear door lock on my 'M'. The door is sagging a bit so the pin would not engage. Had to use a round file to elongate the hole in the door. Also ground the rough edges off the
cam so it rotated a bit smoother. Works fine now. Took the lock to a locksmith to have it keyed to the front door key.
The pinz is a continuing process, always learning something. That door lock is not very complicated a device.
Happy trails
I read about the yellow dot and blue dot discussion in the old section.
No one really knows it seems?
http://www.real4x4forums.com/PinzgauerB ... yellow+dot
crcpinz
Post by crcpinz »
Mine has a yellow dot with fingerpainted "S i/c" (or S i/o) under it. No idea what it means.
Si vis pacem, para bellum
1976 710K
GenevaPinz
Post by GenevaPinz »
crcpinz wrote:Mine has a yellow dot with fingerpainted "S i/c" (or S i/o) under it. No idea what it means.
i/o might be "in ordnung" (in order), which would be a good sign :wink:
Jan
'72 Pinzgauer 710M
