Battery Cut-off Switch
PhilH
Post by PhilH »
Does the battery cut-off switch eventually go bad. Mine is ocassionally temperamental, but now I have no juice. Can you clean these; spray something on them; or do you just end up replacing them. They seem so simple. My batteries are in new condition.
'74 710m
M101A2 Trailer
'69 Firebird Convertible
Re: Battery Cut-off Switch
Take it out and clean the contacts. I used carb cleaner. R & R. It is under the vehicle and exposed to everything.
PhilH
Post by PhilH »
Well Krick, I tried cleaning the terminals, but with no luck. Then I tried getting inside the switch, but found that was nearly impossible as well. I found an identical replacement at Napa for $10 and that did the trick. Works great. Thanks for the advice though. Always enjoy reading your comments and looking at your "enginuity" on your pinz.
'74 710m
M101A2 Trailer
Thanks. What was the number of the Napa part?
Others may want to know that as well. I will check it out when I get that number.
If you have a pic of the part that might also be helpful.
Morris
I think this is the one PhilH is referring to: http://www.napaonline.com/Catalog/Catal ... 0293960637
I saw it recently at my local NAPA store for $8.55. Not a bad price and it's nice to know it works okay.
Rated for 24V and 300 amps. I've got relatively new Hellas in my 2 so haven't tried it.
PhilH
Post by PhilH »
Hey Thanks, that is exactly what I put in. The previous owner had already installed a similar configuration, and just by chance on a Sunday I tried Napa. I thought I was going to have to order the Hellas, but as always, Napa comes through. It was nearly impossible to get inside this thing.
'74 710m
M101A2 Trailer
