VDO washer tank and manual pump.
cascade.king
Post by cascade.king »
Thanks to compunerdy!
A perfect fit and application for my Haflinger Pathfinder!
compunerdy
Re: VDO washer tank and manual pump.
Post by compunerdy »
Glad to see it go to a good home..
Tim
1975 710K
Heinkeljb
Post by Heinkeljb »
The washer bottle system really was an after thought for them wasn't it. Why did they put in "in" the cubby hole? It's awkward to remove and refill, even more so if you try and fill it in place.
I put a one way valve in the line as I found the pump would empty if left for a while and you have to pump several times before it even started to squirt water - and it does not squirt very much for each pump.
Just me "venting".... :P
John
