Does anyone know if there is a less expensive oil temp gauge available for a Pinz other than the one from Swiss Army Vehicles?
Pinz VDO Oil Temp Gauge
1973 Pinzgauer 712M
It's like being a celebrity driving this puppy around town. You can't go anywhere without someone stopping you or coming up to you to talk about it.
Re: Pinz VDO Oil Temp Gauge
I don’t know if threes a less costly gauge however I question the usefulness of an oil temp gauge on a Pinzgaurer. Mine came with a VDO oil temp gauge installed by the previous owner, I’d be much more interested in cylinder head temperature. I suspect that with the Pinzgauer by the time you had excessive temperature showing on an oil temperature gauge any damage would already be done.
Must get hot in Mass.
I have driven in the desert when it was 115 F and the thing I was worried about was me getting hot, not the pinz.
I did have one on my Mog though and it was relatively useful in the desert and on extended drives.
Think I got it from SAV. If you are going to get something like that don't cheap out. Get a good one.
Where on the pan would you install it?
Haven't figured out a location. Since it is a VDO gauge, I thought it may be less expensive through a source like Jegs, but I don't know the actual VDO part number that SAV resells.
1973 Pinzgauer 712M
EmbarkChief
Instructions on mine says to mount it in the oil cooler housing.
-1972 710M
Can you install a CHT sensor under the spark plugs or is that a bad idea?
