GAS TANK - What material - Stainless - aluminum - steel
I have a fella here that will build me a new tank...don't think I want to go the route of the lining. Anyway what would be best...I am leaning toward the aluminum.
He is also going to make a seperate tank for under the table in my k that will be around 20 gallons and have a manula rod to activate it.
If you have made one can you let me know.
We will pull out the old one and he will fabricate a one to be EXACTLY the same.
Jer BEar
Jer BEar
- totaljoint
Andre S. had a stainless steel 36 gallon one made and installed on my 712 with a bullet proof (OK, stone proof) gaurd (doubles as a step to climb over the side).
I love it! The range is incredible, don't think I've ever been able to run it down past 1/3 at a single drive (get too tired of driving the beast for that long).
Ed
Ed
gas tank
I had supports made from 5052 aluminum and I mounted them between the windows in the back.
http://s400.photobucket.com/albums/pp88 ... C00105.jpg
http://s400.photobucket.com/albums/pp88 ... C00106.jpg
Still have the one under the body by the main tank though.
Morris
Morris
I think I will just go with the roof rack and put fuel tanks up there. I also have a rack that goes on the back of the truck in the hitch for stuff...just don't want the tanks INSIDE.
I think I can get atleast an extra 10 gallons if I take of the jerry can holder adn extend the tank that way too...GREAT IDEA.
Jer Bear
Jer Bear
So I came up with a solution for my Fuel capacity problem.
I ordered a 50 gallon plastic tank from Cabela's.
It will be mounted right behind my rear seats and then a fuel line will be run to the front to a manual three way shut off. This way I can run off either tank.
I will have to move the back rack up a bit and run the venting etc, but I think it's the best fix.
So I will reline the original tank (have a guy here that will clean it in the caustic tank at the rad shop.
Then I will do the liner. We don't have problems with mods here. This will give plenty of fuel for travelling the yukon...lots of country very lttle fuel stations.
I will take pics when I am done....I have a body and car restorer to give me a hand and he was the one that suggested I go this route. He did the same for his willy's jeep and his boat...they are inexpensive and bullet proof (well kinda)...he has had his in the willy's for years now...no problems
Ps just welding a rack for the roof too....
Jer Bear
Jer Bear
fuel tanks
Could we see some detailed pictures of the fabricated aluminum tank and how much would it cost to have one made. I kinda like the idea of getting rid of the jerrycan. It would also be neat if it could be made to allow for more ground clearance.
Roger Melton
